Been thinking about getting evo 8 or 9 struts which are taller than stock 1g awd struts. Most people prefer a 1.5 in drop spring because there would be a better ride than a 2 in lowering spring because it would ride stiffer because of less up travel. If i cut all the upper strut mounts off the car and weld them higher like 1 inch. I could get lower with better ride quality. Or just use bilstein mr setup off evo without cutting the springs down.
Anyone done this type of mod on our cars? I know coilovers are as better choice but alot more expensive. The welding and fab work is no problem. Would be stronger than factory when done
