If I cut the Check Engine light wire to my ECu will the check engine light go off and will there be any problems at all.
eccept for the one that turned you light on in the 1st placeI've taken out my bulb and have had no problems........
James92TSi said:You can buy the capacitor and resistor for maybe a buck.
Soldering to your o2 sensor harness takes about 10 minutes. It takes longer to get the o2 sensor off the car than it does to do the actual mod.
Or you can buy a pre-assembled one for 15 bucks, and you still have to pull the o2 sensor to solder it in. I really don't see the point in buying the same stuff for 15 bucks and not saving any time.
Well as I posted I rather have one ready made and since two guys have purchASEd this Mil Eliminator I just wanted their advice on which one was the one they have on their cars. That site with the diagram I have along with detailed instructions on how to solder it on and everything. So if you guys happen to catch this part of the post, can I get your advice.... thanks
