Anyone have any infomation on how to go about doing a evo brembo brake conversion on a 1g the fronts I have sorted , just the rears are giving me a headache are there any parts that will bolt straight up ? Any help would be great cheers
There is no way to bolt EVO brembo caliper on 1g. Only if you can make the bracket for it.2themoon said:Anyone have any infomation on how to go about doing a evo brembo brake conversion on a 1g the fronts I have sorted , just the rears are giving me a headache are there any parts that will bolt straight up ? Any help would be great cheers![]()
The stock caliper is only for handbrake.green_bread said:How come they left the stock caliper bracket and what looks to be a brake pad on there? Was the wheel just put on to test fitment?
Ahh.. that makes sense. Thanks, man!mitsumissile said:The stock caliper is only for handbrake.
mitsumissile said:There is no way to bolt EVO brembo caliper on 1g. Only if you can make the bracket for it.
what if you used the the rear evo4 hubs and trailing arms instead of the 1g trailing arms will it bolt up ?
Im gona go down to the ( Pick A Part ) and do some research see if i can mix and match a setup from all types of mitsi's
turbotalon1g said:How did you do the front?
Also anyone reading this, whats better evo or 3s breaks, cause 3s would be cheaper.
EVO's have it in a drumb?mitsumissile said:There is no way to bolt EVO brembo caliper on 1g. Only if you can make the bracket for it.
BTW, here is my 1g friend's car with rear brembo.
