Factory side mount - 93 talon tsi awd
1.6K views 14 replies 10 participants last post by  sleepin1g
Can i safely run 20psi with a small 16g on the factory side mount? I'm not sure wether to run it for now and slap on some hard piping or to save my money and put on a FMIC. I will be putting a FMIC on eventually no matter what. I'm not sure if this is right but i read somewhere that the factory side mount is good for up to 300whp? :confused:
#2 · (Edited)
It's safe to run the side mount to any range you want, but your power will disappear quickly because you can heat soak it if you're doing multiple pulls. If you're just DDing the car, and most of the time will driving will not be boosting, I'm sure it will be just fine.
I'm going to run my side mount with my Big 16g until next year. But I'll be stock boosting.
Also, because I'm just curious...do you have the other mods to support 20psi?
Note: Doh, forgot it was a 1g...not as much flow there.
I run the S16G. I used to run it with the stock SMIC. 17 psi was the highest I was able to do. After 1-2 hard pulls, it was heatsoaked. I ran 20 a few times, but heatsoaked it immediately. I also had supporting fuel mods. That's with hard upper and lower pipes. Do you have a BOV capable of holding that much?
I agree with the posts above. I ran the stock sidemount with my small 16g for quite a few years at 21 lbs but usually with a little race gas mixed with pump gas for added safety against detonation. It's fine for short bursts but I wouldn't recommend standing on it for long periods of time as it will definitely heat soak.
