Do I really need to block off the FIAV? or Can I just loop the coolent line? Is there a difference?
Well I guess you are lucky. When most people simply disconnect the lines the wax pellet never melts, so you always get the higher airflow. This causes you to have a high idle, and there is no way to lower it. The only solution is to block the airflow allowed by the FIAV. On a 91+ it is easy, not so on a 90 TB.Nanan said:I have been driving for about 2 years on my car with the FIAV just disconnected and the coolant lines blocked off.
Why would that happen? In a stock configuration the coolant goes into the TB then goes back out at almost exactly the same temperature. Why would having the coolant skipping the TB (where it's only purpose is to melt a wax pellet) cause your car to overheat? There is no valid connection between these two events.Nanan said:Do not loop the coolant lines into each other, overheating issues can occure.
That would not accomplish anything. The coolant does not enter the air path. They are completely separated. The coolant melt a wax pellet, which in turn closes a air passage, it is this air passage that we want to permanently close.zack said:Would you be able to shoot water in the coolant lines to see where it goes, then block off the path?
I've never looked closely at a 91+. The FIAV itself might be the same, the TB it goes into is definatly different.Brandon92DSM said:The interesting thing is that CAPS only lists one Part number for a 1G turbo.
MD614454 - "Valve, Fast Idle Air." (In case anyone cared)
The 90 model FIAV obviously looks differnt tho?
Sorry. The price was in my original post. $135.00 shipped. Great price and great part. I'm still very happy I did that.zack said:how much was it?
