Ok so Ive got Fidanza cam gears and I have a 95 GSX with a 7 bolt in it. I was looking at the stock cam gear and there is a metal plate on it that looks like it is used to trigger the cam positions sensor. It looks just like the one for the crank angle sensor.
My question is do I need to remove the metal plate on the stock cam gear and put it on the Fidanza cam gear so that the car will run properly after it is installed? If so what direction does the plate need to be facing (if the engine is at TDC) because there are 2 opening on the plate and four screws that go into it and there are various ways the plate would go on there.
Any input would be greatly appreciated.
