Fuel Pressure on a 2G
3.5K views 7 replies 5 participants last post by  XakEp
Whats a good level to set my FP to on a 2G?
i have my B&M FPR set to 40psi
It sounds like GReDDyGsTurbo has a 2g and set the base FP with the vacuum hose still connected to the afpr.
Base fuel pressure just means what the fuel pressure is at with NO vacuum or boost acting upon the fpr. DSM's come stock with an afpr, of sorts. It will adjust the fp based on vacuum or boost input upon the diaphragm in the fpr. You just can't adjust the base fuel pressure from stock or dial it in after the install of a big fuel pump.
Base fuel pressure shouldn't fall off. I think SeatownGST is referring to when the fuel flow will fall off at higher fuel pressures.
These higher fuel pressures are created under high boost in the afpr. This will get higher linearly with the base fuel pressure you set. So the higher you set the base fp, the more your fuel pump needs to flow at the higher pressures. Fuel pressure (psi) and fuel flow(lph/gph) are two different things.
