93 Talon AWD
Ok so I am in the middle of doing this and need some advice. A little background is I plan on moving the fusebox to the glove box and run the wires through the evap drain tube hole in the firewall (AC is gone). For anyone who has done it, where did you route your wires? I originally thought the engine bay side of the splash shield/fender well cover, but this may interfere with the removal of the engine/trans. This would be way easier to do with the engine in the car, but it is not, and frankly I am new to DSMs so I cannot picture where the trans will sit exactly.
My next thought is running along the subframe connector (proper name?) and then into the evaporator drain tube's hole. Not sure if I would run it to problems with this spot either. Thats why I need help from someone with experience!
