I am long winded.....
Here is the low-down on the greddy tt:
The wiring harness takes care of the units functioning. Now there are 2 wires left, one of them attaches to the e-brake or the clutch and the other attaches to the speed sensor in the ecu. I only tapped the e-brake one because no one is driving off in my car if the brake is up. And I am too lazy to venture into the ecu wiring.
Additionally, the auto mode on the tt has nothing to do with either of these wires. You probably noticed that the tt measures voltage, hold select while the tt is on and it will read voltage for you. I am quite certain that the reason the voltage is there is so that the tt can take a guess at your rpm. The reason for the rpm guess is so that it can add time in auto mode. A-L and A-H have different rpm start times, I dont know the exact rpm.
To set the rpm on the tt, turn off the tt but have the car running. Press and hold the power button for about 5 sec. Eventually some numbers will pop up and that is your rpm. You need to set it with the cars rpm. Use select and timer to set it. Once done turn off the tt and now the rpms are set. Now the auto modes will work how you want them to.
Any questions?
