How much money should one put aside incase their dsm breaks?
1.9K views 13 replies 12 participants last post by  kmieluv
Anyone save a certain amount just incase the dsm goes down? I'm trying to budget for major repairs so I wouldn't have to charge it all incase something breaks. Thanks :)
haha w/ a dsm you better have enough to purchase a new car :) im just playing. there are so many things that can go wrong i dont even know what to tell you to budget for. Most things dont cost more than a few hundred for parts. if you need to include install probably $5-700
Well I guess if my clutch goes out it could be 1G, crankwalk could happen (not sure how much that could cost), t25 could die.
I was thinking about putting about 1-2G aside just incase the car breaks something...then I would have enough to upgrade any not just replace parts
I can do basic stuff with what I have but if anything major happens it's goin to the shop.
w/ 2g you should have enough even if the car crankwalks on you. you can get new completly assembled blocks that are better than stock for about $1800+shipping. so if you can install an engine $2000 should be plenty
Not that anyone who experiences crankwalk firsthand would ever want to put a 7-bolt motor back in their car.. ;)
You can pick up six bolt motors for next to nothing comparitively. Hell, I got two 1g cars for under $700 total. My setup is going to be relatively mild, but even still I am tossing my seven bolt in favor of a six, and just in case I have got a spare six bolt in another car. :)
I was originally planning on having 1k around all the time as an emergency fund. The first time the car broke that was gone, and the rest of the times have kept it from building back up. I pretty much have given up on saving money until I'm completely done with the dsm, with fresh rebuilt everything and lots of aftermarket parts, of course.
Umm.. .. You should get another car. There is this guy, Honcho, is his dsmtalk name I think, who has spent well into the thousands to fix his 95 GST. He just got fed up and bought a 95 TSi and is using the other one as a parts car.
I work at a reputable repair shop, and we advise customers to save 100 a month. This usually balances out well for all major repairs and maintenance(not oil changes and gas, but most). On a dsm that is going to be run hard, I would try and budget around 150-200. good luck
damn, i keep 3-4g's (but this money is somewhat for mods for someday also)in my savings at all times incase mine breaks down...like it is now...now i just can't find a shop that can fix it except maybe satan....
Dustin
Assuming you have the space to work, I would recommend the shop manual and a decent set of tools. This will save you a tremendous amount of money in labor later. The added bonus will be the 'under the hood' education you will get, which will help you mod properly and safely, keeping later breakage as low as possible.
Two years ago, I couldn't even tell you the difference between turbocharging and supercharging and I had no idea what a blow-off-valve was. Since then I've installed a full intake, full exhaust, turbo, gauges, fuel pressure regualtor, and brake upgrade, not to mention all the little support stuff. I've also replaced my lifters and done a full timing belt / water pump job. All myself. Granted, this is still a far cry from the real tuners on this board, but it's plenty of progress, and a lot of saved money. The timing belt labor itself probably paid for all my tools.
Read
Read more
Ask
Tinker
Repeat
although the dsm's are very cheap to modify.......when things break....i mean they break......not the modifying cost alot but maintainance is a itch.........i mean that........
