Anyone knows how to get the sludge out of your 1.8? I am pretty sure mine has quiet a bit since, I have found out that the previous owner of my 1.8 was a spoiled rich kid. Can anyone help?
Agreed. +1sandcobra164 said:Don't touch it!!!! It'll probably leak like crazy once you do!!! I've been there, done that. The gunk is actually pretty good at stopping leaks. Just change the oil and switch to Castrol GTX which is supposed to be great for fighting sludge and all but hopefully won't ruin your seals like a motor flush does on a high mileage motor. I flushed mine and shortly thereafter, changed front crank seal, balance shaft seal and oil pump seal before the next oil change. Good Luck!!!! If it's not broke, don't fix it!!!!
Your moral is cracked. If you sucked it through the vac. line, not enough of it hit ANYTHING oil pressure related to cause the problems you had. MOST of it was burned up in the cumbustion chambers and the rest vapored and went out the exhaust.theblizz said:don't use seafoam. i seafoamed my car at 70-something k miles and the car never burned any oil til after i seafoamed it. then i seafoamed the car again at 80k miles and i noticed i was loosing ALOT of oil pressure. and was burning ALOT of oil. now my cars sitting in my driveway and i got a 6bolt sitting in the garage ready to throw in.
moral of the story. dont use any of that mirical shit in a can.
btw i sucked the seafoam in threw a vacuum line.
