HX40 Turbo
22K views 46 replies 12 participants last post by  andrewshowers
I am looking into getting a HX40 turbo. How well do these spool? How is the power this turbo can throw down?
Lots of info over on Tuners.
HX40:
The 8blade hx40 has a 58mm inducer and flows about the same as a 60-1 (around 60lb/min) with ALOT better high boost efficiency and spool speed. It is the most common hx40 out there. The small bep housing with the hx40 turbine wheel is plenty to reach the full potential of the 60lb/min 8blade hx40 compressor. 20+ psi by 4100rpms with 272s.
The 7 and 6 blade hx40 is called the super40 and has the 60mm compressor inducer. This compressor flows around 69lb/min. You can get this wheel in billet style (think HTA). The non-billet wheel spools as fast as the 8blade hx40 in the bolton bep housing and has done 653whp at 40psi per the holset results only thread. Billet should spool even faster. The t3 .70 a/r BEP housing slows spool about 400rpms. But reports show a significant gain in flow per psi. So expect more power at lower boost with that turbine housing.
http://www.dsmtuners.com/forums/turbo-system-tech/371627-holset-turbos-part-8-a.html
http://www.dsmtuners.com/forums/turbo-system-tech/362444-holset-turbos-faq.html
http://www.dsmtuners.com/forums/tur...o-system-tech/313476-holset-turbos-results-only-complete-installed-systems.html
I'm thinking about an HX40 on my car so I'll keep my eyes on this thread.
just need to figure out oiling lines and what not.
I know there is great debate on this. I did -4 feed from the head and -10 return and had zero issues with mine. One year and about 2500 miles on it.
A -10AN return is not even close to being as big as Holset specifies, but some guys are using them without problems. If you're going to use one, you should "funnel" the drain hole in the upper flange so there isn't such a drastic change in size between the hole in the cartridge and the hole in the drain flange.
You should be feeding from the filter housing to keep the pressure within Holset's spec- however you may need a restrictor to keep from over-oiling the turbo....especially if you're using a -10AN drain which is half the size of what Holset recommends. The oil cannot drain properly, so you must compensate through the feed line size.
These turbos were fed with a -6AN feed line and an oil drain the size of a fire hose on their original Cummins applications. Obviously when you cut the size of the oil drain in half you'll also have to reduce the oil feed size as well even if the pressure remains within spec or you'll have oil running out the seals because it cannot drain properly.
Information taken direct from the Holset service manual for the HX35/40:
Oil return pipes are permitted to decline at an overall angle of not less than 30 degrees below horizontal. All turbocharger applications require a pipe of internal diameter greater than 19 mm which has integrated connectors. To ensure oil drains into the engine under all operating conditions, the return connection into the engine sump must not be submerged and the outlet flange of the turbocharger must be 50 mm above the maximum oil level of the engine sump pan.
Lots of good reading here.
what the diff between the hx40 and the super hx40
Im pretty sure the 'Super' HX-40 and the HX-40 'pro' are the same thing. If so, this is the 60mm version. Im pretty sure these came in 6 and 7 blade variants.
All the others are just called HX-40. Very few have 56mm wheels, which are mostly 6 blades and most are 58mm which have 7 and 8 blades.
#28 ·
Ive never used with a DSM flanged BEP housing but I would say it will be a bolt on affair for you. Certainly the o2 housing will be. Just hope it bolts up to the downpipe.
