ok i got a 92 talon n/t and bought a used jdm cyclone engine for my car and after i put it in well it started but has a bad idle surge and first of all i dont know why a engine with 40k on it would have a leak on it, or the isc motor bad, which i replace along with the throttle body gasket and it looks like all vaccumelines are good and the egr is allready blocked off and the idel is about 1500 rpms and it is not the idle skrew either and when i adjust the idle skrew out i get this whistling noise from the intake, and the surge goes faster and faster as i adjust it out, but when i adjust the skrew in the it slows the surge down and when i close off the skrew all the way tight it stops the surge for the most part, except for every once in a while but i still cannot get the idel below 1000 and i think it is also running real rich and throttle response sucks, and the engine i replace had a 182,000 miles on it and the cyclone does not seem to be that much quicker, but i think that is from running rich, or lean i dont know. i have searched and everything i have found out i have tried and now i am hopeing someone can help me out. oh yea and how do u adjust the lean rich mixture, or is the idle surge causing that. thanks in advance.
