Volume is one of the parameters for density, the other being mass. Volume measures how much space a substance occupies. Mass measures the amount of matter in the substance. Density then shows the amount of matter in a given space for a substance.
Density Formula
The mass of an object divided by the volume of an object equals the density of the object (mass / volume = density). Density is often presented as grams per cubic centimeter (g/cm3).
Increasing Density
If the volume for a mass of substance is decreased, the density increases. For example, compressing a gas into a gas cylinder increases the density of the gas.
Decreasing Density
Increasing the volume of a mass of substance decreases the density. Releasing a gas from a compressed gas cylinder will decrease the density of the gas that was contained.
Compressibility
Changing the volume of a mass of gas is relatively simple, and gases are regarded as compressible. Liquids and solids resist changes to their volume and are considered incompressible.
Design and Function of a Turbocharger: Compressor The turbocharger's basic functions have not fundamentally changed since the times of Alfred BĂĽchi. A turbocharger consists of a compressor and a turbine connected by a common shaft. The exhaust-gas-driven turbine supplies the drive energy for the compressor.
Compressor
Turbine
Control system
Bearing system
Design and functionTurbocharger compressors are generally centrifugal compressors consisting of three essential components: compressor wheel, diffuser, and housing. With the rotational speed of the wheel, air is drawn in axially, accelerated to high velocity and then expelled in a radial direction.
The diffuser slows down the high-velocity air, largely without losses, so that both pressure and temperature rise. The diffuser is formed by the compressor backplate and a part of the volute housing, which in its turn collects the air and slows it down further before it reaches the compressor exit.
Operating characteristicsThe compressor operating behaviour is generally defined by maps showing the relationship between pressure ratio and volume or mass flow rate. The useable section of the map relating to centrifugal compressors is limited by the surge and choke lines and the maximum permissible compressor speed.
Surge lineThe map width is limited on the left by the surge line. This is basically "stalling" of the air flow at the compressor inlet. With too small a volume flow and too high a pressure ratio, the flow can no longer adhere to the suction side of the blades, with the result that the discharge process is interrupted. The air flow through the compressor is reversed until a stable pressure ratio with positive volume flow rate is reached, the pressure builds up again and the cycle repeats. This flow instability continues at a fixed frequency and the resultant noise is known as "surging".
So a turbo compresses air and changes the mass, but the volume stays the same. Then a larger turbo would give more volume and mass, and thus the reason for more fuel. So Your stock injectors are set up to accomidate your stock air volume and mass, but when you change that, the computer sees way to much air not being used, and thus opens the injectors longer untill, as its put the duty cycle is over 80%, resulting in "not enough fuel" being provided.
Could that be cured with a higher volume pump, and regulator then. Is it that the injectors run out or the pumps pressure not being enough to get it in there fast enough. Or at this point, both are relavent.
