21 - 29 of 29 Posts
So did you replace the spark plug wires yet? Did you damage the O2 harness when you were installing the O2 housing? Have you checked for boost leaks? just wondering exactly what you have tried so far. Spark plug wires could be the culprit, might be running on 2 cylinders or something...
Might want to check the spark plugs too, just in case. good luck.
I got my money on boost leak now. My intake pipe came off yesteday and it had the exact symptoms you describe. Wouldn't make power at all and it would stall if I didnt rev it.
Discussion starter · #25 ·
well thank you DSM gods. u all nailed the boost leak dead on. i guess i had a quarter inch between the exhaust side of the turbo and the mani...thanks again guys u always help
its running like champ now except whenever its starts to boost it just redlines...fuckin clutch..thats next....
Just FYI that would be an exhaust leak, not a boost leak.
Discussion starter · #28 ·
yeah there was also a kinked IC pipe...so yeah... little bit of both...
21 - 29 of 29 Posts
