Ok I have been struggling mating the tranny back up to the block. They are both out of the car. Motor assembled and on the hoist. the torque converter is bolted up to the flexplate (4bolts) and the TC is in the tranny housing and on the shaft. We put the TC in the tranny on the shaft and pushed it back, then moved the motor to the tranny. I can get the top bolt and the side bolt in, but on the one side where the starter is, that side for some reason does not want to get together. I have tried loosing at bolt, keep them a bit tight, tightening them all thinking it should pull them together, C clamp, Ratchet tie down. All no luck. Its just the one side that will not come together.
What am I doing wrong? Suggestions?
Would it be easier if I tightened down the bolts I can, then drop the block and tranny in. Tighten down the engine and then from the side of the car push on tranny, with a jack underneath the tranny?
I spend about 4-8 hours just trying to get them together. Its a pain in the A**
