Hi,
does somebody know if this is a eeprom?
took it from my 95 GSX ?
thanks a lot
Mike
thanks a lot
Mike
No not all 95's came with an emprom. i know that because right before ordering the DSMlink i double checked mine and sure as Sh1t mine was non-eprom. i am guessing that early model 95's had it then they changed it just to screw me over....punisher said:Didn't all 95 turbo cars have eprom? That is definately eprom.
Early models had it of the second generation as that is how mitsu tuned the first 2g turbo models, simply burning chips until they got it right.XCalibirTsi95 said:No not all 95's came with an emprom. i know that because right before ordering the DSMlink i double checked mine and sure as Sh1t mine was non-eprom. i am guessing that early model 95's had it then they changed it just to screw me over....![]()
Ok that makes sense, I was reading somewhere that 95 was the only year that 2g's could come with eprom and I just assumed they all were.XCalibirTsi95 said:No not all 95's came with an emprom. i know that because right before ordering the DSMlink i double checked mine and sure as Sh1t mine was non-eprom. i am guessing that early model 95's had it then they changed it just to screw me over....![]()
stevep said:No it's not a EEPROM ECU but it is an EPROM ECU.
The difference is EEPROMs are electrically erasable like flash memory where a EPROM is simply erasable. In the typical case by UV light. None of the factory 1G or 2G ECUs until 98 or 99 used any sort of EEPROM.
Steve
Not that it really matters, but a while ago I remember reading something about there being 5 different versions of the 95 ecu, with very slighly different fuel trims and things like that. I'm pretty sure 4 of those versions had EPROM.punisher said:Ok that makes sense, I was reading somewhere that 95 was the only year that 2g's could come with eprom and I just assumed they all were.
http://www.dsmlink.com/faq.html#eprom_ecu
In the link they say that non-eprom 95 ecu's are pretty rare.
