I think this may belong here instead of the help section (where it is now), but I'm not sure so administrators please decide. Thank you.
Here's the full run-down... (MODS list below)
About a month ago I flushed my cooling system. Drove the car to and from work for about a week..no problems. Then, that weekend after I had done the flush I went to the gas station ("normal" driving) to get something to drink and when I shut the car off, after about 15 seconds, the overflow bottle started pissing coolant. Temps were fine (but I could here it "boiling"). I disregarded it. When I got home I topped it off. Drove the car "normally" for about 2 hours that night...no problem. Well, then the next day I took it out w/ some 110 race gas and on my first run through 3rd when I stopped the car it did the same thing again...pissed coolant out the overflow (lots of pressure in the coolant return hose). Temps were still fine though. So I let it sit at idle for about 10 minutes and when I checked the logger I was at 214 degrees. So I shut the car off and let it sit for a few minutes, started it up, and drove it home (temps stayed between 197-202). Well, I changed the rad cap and that did'nt work. So I'm thinking head gasket obviously. So I checked the oil and the coolant. NO signs of them mixing together at all. So I called Jeff at Turbotrix and he said it was probably due to my stock "shitty" cooling system and that somehow air was getting past the head gasket causing it to pressurize the system. So he said I should upgrade the cooling system and I may "cure" the problem (at least for now and possibly for a long timeto come). So I ordered a Fluidyne Radiator, 12" 1400CFM fan, bought a new 180 degree therm., and also got a bottle of water-wetter. Which brings me up to today.....
I installed all of that this morning as well as changed the oil (Amsoil synthetic 10W-30), put in new 7ES plugs (.028), and checked the compression and ARP head stud torques. Compression was 195 PSI SOLID across all 4 and the ARP's were good and torqued. So I start the car and let it warm up and cycle through a couple times through the thermostat and then I top it off and take it out for a drive. Coolant temps are great (184-194). Never saw over 194 even under 19 pounds of boost (still has the 110 octane in it. Car feels strong as shit!!!!!). So, after a few "hard" runs through third I drove back to the house and after about 15 seconds the overflow bottle pissed out some coolant again!!! There was a LOT of pressure in the return hose as well. So again, I'm thinking "Great, $450 later and still same problem I'm thinking...head gasket. Here's the kicker.....I let it cool a bit and took off the rad cap and topped off it off. BUT!!!!!, now I notice there is OIL IN MY COOLANT! And remember, this coolant was put in about 15 minutes prior to this happening. My oil looks absolutely fine though. No signs of coolant in the oil, just oil in the coolant. So I drove it home (about a 20 minute drive) making sure NOT to boost on the car AT ALL. When I got home and checked the coolant hose and overflow bottle they looked normal (no pressure build-up and overflow bottle still had just under the full mark in it). So yet again I give Jeff a call and he said that it may be a cracked (damaged) OIL COOLER. And that, "in theory", since the pressurization problem only seems to occur under boost that maybe since the oil pressure increases with boost build-up that maybe it was also causing the pressure build-up in my cooling system. He said that in all the HG's he's seen blow he has never seen OIL IN THE COOLANT, just the opposite. He said that he HAS however seen about a dozen broken (damaged) oil coolers and that has caused the oil-in-the-coolant problem. He's iffy about whether or not it would cause my pessure build-up though. He said "maybe".
So basically I'm looking for insight from any and all of you that may have some ideas on this. Could it be just the oil cooler? Or oil cooler AND HG??? (god forbid!) Cracked head??!! Even Jeff said it was strange. Oil in the coolant AND pressure build-up. Hmmmm, please help!
