Lost traction; hit curb. What should I check for damage?
2.3K views 15 replies 12 participants last post by  eclipse90_16g
It has been raining on and off today for the first time in nearly three months and as anyone who lives in an area which sees little rain knows, after the first rain the roads are fucking slick with oil. Driving my 1996 Eagle Talon TSIAWD, I was on my way home from dinner; second to last turn before arriving home I make a left turn onto a three lane road at a light.
I've owned the car for about four months and this was probably the second time I've driven it in wet conditions. This was also the first time dealing with a loss in traction in anything other than a front wheel drive econobox, but I had read that when the back end starts to go out like that you are supposed to keep a steady throttle pressure and steer the wheels where you want the car to go.
As I brought the car through the turn I felt a loss in traction and the car slid diagonally into the middle lane, rear end drifting out to the right. As I finally caught traction again the car over-steered in the direction I was trying to correct (which is surprising because I really didn't think I was over-correcting). I over-corrected the car back to the left, let off the gas, swung again to the right, then back to the left in a heart stopping fishtail. After the final over-correction I realized there was no avoiding the center median this time. I mashed on the brakes to slow the car down as much as I could before impact. I went up over the median with my front left tire and down into the turn lane. Another dozen feet and this turn lane would have given me what little room I needed to finally correct the car as I was only going about 5mph when I hit the median.
I limped my car the last quarter mile home expecting to at least see a bent rim. I think I got lucky in that the only visible damage is a scratched rim and concrete abrasion on the side wall of my tire. I took the car out for a short trip around the block and the car seems to be still aligned (surprisingly) but the rattle I had previously in that wheel when going over bumps seems to have intensified. I'll have to check the car over more thoroughly in the morning. What should I inspect for damage?
I'm pretty shocked that the car would come around so violently at such low speeds. I doubt I ever saw more than 15-20mph or one-third throttle. Looking back it felt like the front wheels might have caught before the rear and flung the car around.
what kind of tires are you running?
You'll want to check all ball joints, tie rod end, knuckle, shock and spring assembly. You may have lucked out and avoided too much damage but you will definately want to find that rattle. 2g's are notorious for having the control arm ball joints die. If I had my guess, I'd say check the tie rod end first.
^^ yeah Definitley check the tie rod end. are you sure your tires arnt mounted backwards. how much tread do your tires have left on them? ive gone on the highway in literally POURING rain in bald tires, and i was barely sliding around.
Wow, that sounded a bit dramatical man, a bit worse than what happened to me though, i lost traction in a one way street in ny comming out of a turn at 25 mph, the roads were a bit wet, but because im fwd, i got owned, i was trying to correct the car w/o smashing into another car, and the block i was in, cars were parked on each side llool, i barely missed 2 of the 6 cars i was fishtailing by, one which was HELLA close, cuz i thought i was gonna hit it but right after i got outta that turn, car oversteerd and i gto it back under control, but i was a bit shakey lol...but yea check your lower control arms, and ball joints, i had a problem where my right wheel would squeek all the time lol..
My tie-rod end broke on my car when I went over a parking stopper. My steering wheel shook whenever I got over 35 after that. Does your steering wheel shake?
#12 · (Edited)
Thanks everyone for their time and replies.
This morning I checked out both the front and rear suspension on the driver's side of the car. Neither had any visible damage, but I was unable to locate the source of the rattle on my front wheel. My lower control arms had stickers with Mitsubishi part numbers on it which makes me think they have been replaced under recall, but I plan on taking it to Chrysler shortly to have it and the trasnfercase inspected.
I've located the cause of my lost traction. While my front tires are both the aforementioned Michelin Energy MXV4 Plus XSEs (205/55/R16) and in decent condition, the rear passenger's side tire is a Dominator Touring MR II and the rear driver's tire is a Continental EcoPlus Touring Contact. The Continental seems to be the catalyst as its pretty bald.
I guess its time for her to get some new shoes all around.
Sounds like you were going a little fast for the curve. I have to try pretty hard to loose traction in my awd. However, most Michelin's do suck in the rain, so you had that goin against you.
If the tread depth is as different as you make it sound between your tires, I would get those replaced asap. Your center diff and transfer case are not happy with you right now.
i would check the whole steering system.
have it aligned to make sure you didn't forget anything. if you bent anything the alignment will tell you because it won't align up. then get some better tires and make sure it aligns before you put the new tires on so you don't mess them up.
