max boost from a evo3 big 16g
7.8K views 16 replies 14 participants last post by  Chicago_DSM
what is the max boost i can squeeze out of this turbo? and what is the min psi?
To vague of a question to give a real answer. If you have a typical setup(injectors, pump, AFC, etc) then you should be able to hit ~20psi on pump gas and slightly more on race gas. Minimum psi is tough... you can technically run 11psi, but without an external wastgate that will quickly creep to 17+.
BTW, please post in the right forum and spell check yourself from now on.
you can boost at much as you like it is up to you when you want to stop before it blows ups :D
Since no one really answered your question I will. You cant get the turbo to hold more than 22-26psi. Different for every car. When slowboy made there 400whp on a 2.0 with the evo16g, they pushed about 30psi then it would drop to about 22-24psi by redline. They said the spike caused the power to hit real hard, but the housing just cant keep up.
