181 - 181 of 181 Posts
John, Checking in. Haven't seen your update for while. Hope your build works out great as I saw in the latest update. I just finished my build on 7 bolt on 95 GSX with very similar setup with your. ACT 2600, acl trimetal bearing, HKS 272, cometic metal headgasket, stock crank.... I am currently breaking in the engine now it's sitting at 12 miles.
I'm curious if you have experienced any rpm drop when you depressed your ACT2600 clutch? did you remember if any rpm drop happens when you just fired up your new engine?
I aligned my thrust bearing as I pryed the main bearing cap backward as having someone to depressed clutch half way for me.
Any signs of increased crank end play yet? I know I shouldn't be worried as my engine only has 12 miles, I need to be ware if I have done thrust bearing installation right. other than that, I did some full throttle break in already.. it sounds like a beast.
Andrew
