I hooked up a boost leak tester today to my intake side on my turbo like you should. I set the engine to TDC. I presurised the system and I heard a leak right between the two halfs of the turbo. Not where the exhaust half joins on but closer to the lower intercooler flange. I know its not the flange gasket. Its coming from the turbo housing it sounds like. What would that be? When you pressurize the system doesn't it only go through the intake half of the turbo, then to ic, up to intake manifold and stops in there basicually? Thanks!
