i have a '91 gsx and i really don't want to contort my hands to put the coolant lines back on the throttle body. in addition to that, wouldn't that help in the air temp department since it no longer has to go by the hot water? or is it a bad idea?
thanks for the input. i live in socal, so when we complain about cold (anything sub-60*), the rest of the country calls us crybabies. which is fine. so i'm not too worried about the cold idle since it doesn't get too bad here. but why can't i just go ahead and leave the lines off?1QuickChic said:To answer the question. you need to know what the water lines do. so i will offer some input. The water lines are for the fast idle air valve. it makes the car idle faster till it get warm, which at that point melts some wax in the t-body which in turn close off the passage. it can be eliminated. but you cant just leave the line unattached, you will either a. make a plate to sandwich between the assembly. or b.(what i did) disasemble and silicone everything inside. either way by doing this it makes your car not idle when cold and you will either have to jack around and accept a higher throttle, or let sit and help the car warm up in the winter. hope this helps![]()
^im with rippin i did the same thing he has done..no large cams yet but he showed me his block off plate i then made my own out of SS and have had no problems since no loopy idle nothing, cold weather requires about 20 seconds of your foot on the pedal but thats no biggy..RippinGSX said:Mine is completely removed, lines are looped and a blockoff plate is installed and my car idles fine with large cams in hot or cold weather at 900rpm. I can't see what the problem is here people.
