Well, to start, I would like to ask about tires. Now I know quite a bit about mechanical, but tires are a little bit different, and I understand about the numbers, but other than that they are a bit tough to understand. I recently bought tires, and then I read on the door that the tire size is a P205/55R-16, however the tires I had on there before, and the ones I have on there now are a P225/50R-16. Is this going to be ok, or are they going to wear faster, or be any problems at all?
Secondly, I have been having a boost problem. Here is my issue:
Took the car to a mechanic (and he is a reputed one) to have the motor swapped. I would have done it myself, but I really have only swapped one motor before and it was a nightmare, and I needed my car back ASAP. So he put in the new motor (and transmission if it matters) and hooked it all back up. So I also asked him to boost leak test it, which he said he did, and he said he set my MBC at 15. Now here's the problem. Every time I am idling, etc. the vac is good, at like -20. I've put all new hoses on, so no leaks. But when I get into boost, it will only hit like 5 and it will peg off of the 5 continuously. What the hell could cause this? Everything seems fine and dandy that I have checked over so far, so I don't see what could be causing this issue...
Three, I have the wrong transmission in my car. See, I bought one of those "JDM" motors off of ebay (which should have been a clue, as the eclipse wasn't made in Japan)...and it turns out long story short I bought a Mitsu. RVR motor/trans. It's all installed, and runs fine, other than a CEL about the transmission, and not having that last gear because I don't have a lockup TQ converter, but is this going to do any damage to my diff. or anything running it like this? It was expensive to do all of this for me, so I don't have money to change out the trans right now...when I get the money I will. But what do all of you gurus suggest? I'll take any help I can get!
Thanks in advance,
Javey
Thanks in advance,
Javey
