Ok here is the deal I have a 2g gst with a 6 bolt. I have been trying to fix a misfire that I have haf for the last month or so. It only misfires when you try to cruise and it gos away when you either shift or left off the gas for a while I was told my some members and all me reading that is due to the 6 bolt swap. So I check and changed the plugs and fuel filter 3 diffrent times check gap. Cleaned injectors and fuel rail . Looked for boost leaks and loose wires. No luck I figured it was time to order ecm link and I installed it last night, well today my computer shit the bed so iam screwed and need to drive 8hrs home for my dads birthday. I have read that I can take the sensor of in the link but due to no comp. I could also just cut the tps wire. Is this true. If so I only want to do it if I can repair it and it is kinda quick and easy but won't hurt much. What do you guys think. I am leaveing tonight thanks for the help.
P.s I typed this on my phone so sorry if grammer is off.
