Vacuum Line Elimination
1.9K views 7 replies 4 participants last post by  91EclipseGuy
I have seen a beefy thread amongest the turbo boys who proclaim that they safely removed their vacuum lines on their 1g eclipse by basically capping off the plugs. Just a notion, but has anybody with a non turbo eclipse tried doing the same thing? I have only eliminated 1 vacuum line and that was the one to the egr, i had fabricated a block off plate, so there really was no need for the line going to it anyway.
My guess by looking at taboo's website, that us 1g non turbo owners would only have to plug up the 3 nipples on the throttle body while leaving everything else exposed.
Just an idea, but can the na eclipses follow the same diagram/concept as the turbo charged veichles concerning the vac line elimination?
So all you did was block off the nipples on the TB while leaving all the other nipples exposed to the atmosphere? What did you use to block off the nipples....I heard that people run a bigger vacuum hose in a loop to close up the nipples, but don't turbo cars have 4 nipples so they could just easily loop a hose over 2 nipples, crimp the hose, then run it to cover the other 2 nipples? I don't know how you would loop the nipples on a NA car since there are only 3 nipples. I would use plugs but I am afraid that over time they would blow off.
#4 · (Edited)
I got some vaccumm caps from advanced auto and put those on and used some real small zip ties to hold them on for the Talon. You shouldn't even really need to use the zip ties as long as the caps fit snugly since you dont have to worry about boost in the TB trying to blow the caps off.
And yea, I only blocked off the nipples on the TB, I just left the ones on the egr valve, thermo switch and ect. open since it doesn't really matter anyway ;)
