I need to know if it is worth buying. Also if there is any problems with it.
The Venom 400 is a POS. It tricks the PCM into thinking the air intake charge is colder than it is, which causes the PCM to dump more fuel through the injectors.1Fast96RS said:as well as the Venom control module or VCM 400, i was told and also read in a thread awile ago it does nothing for our cars, cept reposition the throttle, so it seems like you are gaining HP but it just allows more airflow in your intake, by making it seem like your into the pedal more then you are.
