Weird PS pump noise HELP
628 views 3 replies 2 participants last post by  IcemanTSi91
Ok so I just got home....
All of a sudden my Power Steering Pump or something real close is making this sound (sounds like fingernails on a chalkboard)
The steering wheel only turns is like 1/4 turns..or jerks in 1/4 turns..no smooth action....
I had my bro turn the wheel while I looked at the PS pump and when he turned the wheel the pulley almost stopped a bunch of times or it turned real slow as that sound was being heard
what the fuck is it??
btw, I did fill the PS resevior with a little more fluid just to be sure but it didnt do anything
The pump or the belt to the PS needs changing.
But...come to think of it, its just the pump. Have it changed, than you'll have to work that car for a while, turn the wheels full length several times till the sound will subside.
i fixed it.. the ps pump came loose and lost tension on the belt ( i could untighten the two bolts with my fingers :eek: ) so I pushed it back up and tightened the fuckers down and it works fine now.:D
