I've looked through about 12 pages of threads and haven't found much. Lately, the steering has been a little waunkee. When i'm accelerating in a turn, and press the clutch, the steering wheel seems to become loose for a sec, but then returns. Even traveling at highway speeds on a loopy on/off ramp, it does the same thing. Not really a big deal hoestly, but in the last couple weeks, driving down town, as I'm approching a red light, the car will really want to pull to one side. Which side, varies on the angle of the road. This will usually only happen during deceleration. Driving in a straight line or turning slowing, everything is just fine
Checked the obvious: lugs are tight, picked up the car and the front wheels aren't loose, ball joints are greased regularly, checked brakes (both calipers are fine, pads + rotors have 3000 miles on them) the fluids are full, and I even put in some NAPA PS fluid cleaner/leak fixer > 500 miles ago, and the car had a 4-wheel alignment about 5K ago when I got the new wheels.
Does it sound like it's time for a new Power Steering pump or maybe new rack + pinion? Anything else I should check? I should add, the car doesn't make any noise when this happens either.
