I bought the car the way it is and the only reading I can get off of the wideband is by selecting the rear02. If I select the front o2 it just shows 10:1 or so and my front o2 volts go inactive (20 and 80 only). I noticed that the wideband sensor looks as if it was wired into the front O2. I see that it has the nice velvety wire casing and really clean white and blue wires. For some reason the blue wire was cut from the clip and rerouted to the firewall (I assume to the ecu pin). The rearO2 sensor looks interesting to say the least. It has zip ties in multiple locations. Which obviously were not rigged the way they are by the factory. It's too late and I'm too tiered of messing with the car to see what pin that white wire is run to. Can someone please explain to me what was trying to be obtained by wiring it like this? I'm not very good with electric wiring so any advice would be very appreciated.
