121 - 140 of 182 Posts
Updates? Last time i posted i was still in England. Now in San Antonio.
Any closer to the 200? Any exact output figures? Any asthetic chagnes?
Discussion starter · #122 ·
Just a quick update for you guys, the original engine decided it was time for retirement at 50k mile, and toasted a piston, turned out I had a crack in the intake manifold. So far new engine is in, and here is what its equipped with ;
Bottom;
Ross pistons .30 over 8:3.1 comp with coatings
Pauter connecting Rods
ACL tri metal bearings
All new oem pump,seals and oil filter housing
New arp hardware
Earls -10an 32 row oil cooler with -10 lines
Top;
Fully ported head with ferrea super alloys, and app goodies
Soon to come is pictures
I have changed other things on the car as well, got some 17x9 zigen zr+ rims with azenis rt615 245-45 17 tires, and a new suspension to boot.
This thing should scream fellas!
Crack in the intake manifold! What was the air fuel ratio when the piston cracked?
Discussion starter · #124 ·
The log was all 11.5- 12.0 egt's were fine, no knock, on 15psi, i didnt figure it out till i pulled the head and the piston was missing the top of the crown, totally mystified me.:confused:
Any more updates, I love your car. Would also like to know how close to the 200 mph mark you got! :D
You can melt pistons and not knock, knock is a timing issue, at every a/f ratio there is a theoretical timing value that the engine will not knock at. You can run a car lean to melt and still not have a knocking issue which is why people run 4 individual EGT gauges.
As for the ARPs, good luck...i'd have dumped them a long time ago.
K man nailed it right on. As usual. This is why I frown when people overlook there EGT's and only rely on there wide band.
I'm PRETTY sure the cars running the Texas mile trapping 200mph+ are not running/monitoring EGTs' in every cylinder. I know the 228mph *record holding* Supra wasn't. EGTs are 90s technology. To me...they are pretty damn useless as far as tuning is concerned. I am sorry, but the tempt. reflected on that gauge (if placed in an exhaust runner) does NOT neccessarily depict actual tempt of the combustion chamber at that particular time. That's a big con on that monitoring device. Tune the car on a conservative afr and you will not have to worry about tempts high enough to melt a piston. EGT gauges are not a pre-requisite. Give me a wideband over a crappy EGT gauge anyday. :)
:rolleyes:
You need both. How are you suppose to tell if you are starving the other cylinders, having injector issues, fouled plug, etc, etc.
16G_tsi_awd said:
:rolleyes:
Duh...you inspect the plugs. :rolleyes: That will tell you everything right there.
Narrowband O2 sensor downward trace will also show/indicate misfires. No crappy EGT gauge needed there. :) Don't tell me "You need both." People have been tuning just fine without them. It's not the mid-90's. ;) :)
Narrow band O2 sensor downward trace will also show/indicate misfires. No crappy EGT gauge needed there. :) Don't tell me "You need both." People have been tuning just fine without them. It's not the mid-90's. ;) :)
Breaking pistons and throwing chips of valves is not "just fine" Not all of us have black nitride coated valves.;)
I'm done cluttering some ones thread.
Discussion starter · #135 ·
Ok now that ,that is all cleared up, on with the qrtr time.
Before the new turbo, cams, engine management, on azenis st115's I ran a 13.0 @ 119, 60 ft was 2.9, I pretty much spun half way down the track,with the new set-up I have yet to run, we will see what happens, probally going to be a 15 somthing @140+ lmao :p
Discussion starter · #136 ·
Teaser pics
cage
down pipe
Non gracious pic of wheels and tires with flare
My first thought was "thats the worst 60ft time I have ever seen". Then I remembered your fwd and making crazy power. Didn't your car used to be a n/t 1.8l or something like that, I think I read that in an oldschool thread awhile back?
Does Mavisky know you swiped his flares? Dude might come looking for them.:D
Discussion starter · #138 ·
Yeah it use to be nt2.0, Dont tell mav he doesnt know they are gone yet:p j/k
