i have a 98 gst with jus a 1st gen bov i also have a blown laser turbo it has a 16g on it i was gonna put it on the 2g but i was wonderin how much power can i make on the 2g with like 16-18lbs cuz it is a everyday driver n a 7 bolt ?
I have a 98 GST also.91turbolaser said:i have a 98 gst with jus a 1st gen bov i also have a blown laser turbo it has a 16g on it i was gonna put it on the 2g but i was wonderin how much power can i make on the 2g with like 16-18lbs cuz it is a everyday driver n a 7 bolt ?
I ran 24psi from a 50 trim on my bone stock 7bolt everyday. It's all in the Tune...91turbolaser said:i was getting the 255 pump n atleast 550s n safc n tuning but i dont think i can put that much boost on a stock 7 bolt? n daily driver?
Sure you can.91turbolaser said:i was getting the 255 pump n atleast 550s n safc n tuning but i dont think i can put that much boost on a stock 7 bolt? n daily driver?
2L Rice Cooker said:15 PSI: 290 ft/lbs 344 WHP (crept to 20 PSI)
20 PSI: 344 ft/lbs 344 WHP
25 PSI: 400 ft/lbs 375 WHP
30 PSI: 436 ft/lbs 397 WHP (fell to 23 PSI at redline)
I think slowboy is a reputable source![]()
Nope that is from their recent turbo testing, done on an 8.3:1, 2.0L With a conservative tune.nailmark said:I think your refering to runs on there 2.4 or 2.3 with the mhi evo III 16g...i dont think most pple will see numbers like that out of a 2.0
That's what I thought to. I'm cranking it up after the new motor is broken in.2L Rice Cooker said:Nope that is from their recent turbo testing, done on an 8.3:1, 2.0L With a conservative tune.
i asked this question back a while ago to extremepsi (about their evoIII 16G 7cm^2). they claimed 380whp. and this (i think) was considered with a port job, but maybe not. if you're running around 400whp, you're pushing it, for most 16Gs. you dont want your turbo to be running on the ragged edge of destruction. thats just unhealthy for it.ProjectSoloGear said:I have a 98 GST also.
It really depends on the 16G you have, but most you can squeeze out of the 16g's for our cars with all of the supporting mods is up to 380hp at the flywheel.
That's why I hate posts like this.2L Rice Cooker said:15 PSI: 290 ft/lbs 344 WHP (crept to 20 PSI)
That's true, a guy at my work was just complaining that he can only get 400whp out of his 50 trim with every supporting mod on there.diambo4life said:That's why I hate posts like this.Now someone is going to bolt on an EVO III on their otherwise stock car and expect to get those numbers. Do you realise that some people with 50 trims on a 2.0L can barely get those numbers? *shrugs*
quickwhips.com said:my wife has a gs-t convert. we ran a ported B16g19psi on it with 550cc injectors, s-afc, fmic
it went 13.7 @ 104mph on street tires with a 2.2 60'
richie
Yes...........Although my stock 7bolt bottom end is now in the junkyard with holes in it from #3 rod snapping. I don't think it had anything to do with running 20+lbs of boost though. I think that rod was weak from the time of production. Somebody missed something in the production process, hairline crack, bad metal, who knows.91turbolaser said:so u guys r sayin i could run 20 on stock bottom end? daily? as long as i tune tho right
greenstreak said:Most don't top the low 300s at the wheels on pump gas.
