41 - 57 of 57 Posts
So when V3 shows up next week or so then I will be able to access the forms? Ok well fair enough. For now I will be doing searches. There are some helpful links in the wiki I found out. So much to learn this summer. Should be exciting. :)
With all the good things said about sd, I think it would be good to say as well that just from reading over all of this and having very little experience in anything, I would say that boost leak tests would have to be a fairly regular thing wouldn't it? Just to save on the turbo of course.
Yeap, only to control the turbine wheel speed, to keep it in the proper efficiency zone. Which is important, but splitting hairs when your talking about leaks that concern MAF cars. Besides the physical efficiency of the turbo, the car will run the same leaks or no leaks. The performance hit from a boost leak on a MAF car is huge, and ridiculous, compared to SD.
A word to the wise when running speed density. Make sure you don't boost higher than the MAP sensor's range. Anything higher and the MAP could revert back to a much lower signal output. Nice little surprise I had on my VPC, luckily I was running high octane when the motor leaned out massively.
I can't seem to find any more info on the SD on ecmtuning or in the ecmtuning forums. Is it included in a V3 upgrade?
WTF, your kidding right? SD is almost every topic that is on there right now. And yes it's included in v3.
Pretty sure it is, and I am also fairly sure I will be ordering the upgrade soon...
Check out www.ecmlink.com They will NOT be shipping any starting today through july 6th.
There wasn't like a big release party or anything, it just showed up in the firmware update. Its not posted on their website yet.
You can see the release information here:
http://www.ecmtuning.com/wiki/v3firmwarechangelog
Also shows all the calibration and setup features they have, to make it easy.
Yeah see I had just went to the homepage and there wasn;t anything said about it so stupid me clicked v1/v2 threads instead of V3 because I am not used to clicking V3 yet but I see it all now.
41 - 57 of 57 Posts
