I have the 1G Eagle Talon 7" Street Intercooler Kit, we have the pipe on the throttle body, but the pipe for the bov is not routing correctly. I need help where to route it because no matter where we go with it, it wont fit right. 527
Oh dude, you were very helpful. It's just frustrating with it being a help section that advertises help RIGHT NOW. Also I would have called the manufacture of the fic but there normally not open at 9pm . Lol, know what I mean. Just on the frustrating part. However, in the end it all works out and it all gets fixed. So thanks for your educated input.Sorry man, I am only on during work hours. Then I can't even see the pics. However I am running the CXRacing one I had difficulty too with the lines to the A/C but was able to move them out of the way. I was trying to help out man. But on a forum it's collective thoughts and it does take time. I had spent several hours figuring out mine as well and no instructions. Sorry man.
Pshhhhhhh...........sounds expensive.What did you expect? This is a DSM forum, if it's not a $20 eBay pos then no one is going to know how to install it.
You shouldn't have to lose AC to use this or any other normal ets, maybe a slim fan but defiantly AC compatible.nope, the only actual cutting was in the
D-holes that run your power steering, and a/c lines, and all I had to do was grind them out till the pipes fit, and then had to pull the a/c fan, and the a/c line. So in a nut shell I get to cruise with the windows down.
it just used self taping screws and it fit just right the first time we mocked the front clip up.
Thats what I thought, I researched that guys had to bend the line to fit it, however, from my experience for the angle the last 90 degree pipe that goes through the D shape hole. the line had to go down and back which puts it behind the radiator edge that would never happen without cripping a line. so it had to go. Also I'm content with the decision because I'm naturally the type of guy that rather have the windows down. I also saved everything so if i want to go stock or a/c then I can figure something else out or put everything back.You shouldn't have to lose AC to use this or any other normal ets, maybe a slim fan but defiantly AC compatible.
Swade
My 2.0 with 272's is happy at 1k rpm idle. Anything less and it doesn't want to take off without a problem.I just hope its not a head gasket or something else more important leaking. Even with a 2.4 stroker and 272 comp cams where should it idle?
But ebay has all of the JDM parts directly from Japan!What did you expect? This is a DSM forum, if it's not a $20 eBay pos then no one is going to know how to install it.
