Thank you for the complament
I wanna do mines different from guys with turbos it's a challenge but I belive I can rise to the challenge.
If guys with Hondas can do it I can too or at least try.
I talked to a guy and he told me to buy these things what do you guys think?
starting with 140hp stock and wanting to reach 200hp is very possible. here is what you would need to buy in order to reach your goal of 200hp.
1. cold air intake system ( aem, injen, or weapon-r)
2. venom intake manifold
3. bbk high volume in-taqnk fuel pump
4. nology spark plug wires
5. denso iridium spark plugs
6. headers
7. cat-back exhaust system
8. throttle body spacer
9. NO INTERNAL MODIFICATIONS NEEDED!!!!!!!!!!!!!!!!!!!!!!!!
Now I'm sure it should at least hit 200 to the flywheel by the time it hits the wheeld I'd probably hit 162hp.
Not bad if this guy is correct I would only need 19% more power to hit 200hp to the wheels where do I get that 19% w/o adding a cam that will cause a bad smog test, I wounder will modifying my computor get me that 19% or should I run a totally different computor system but hide it somewhere?
At least I'll be in the GS-T stock hp area at this point with only 8hp to go I can look to a few more mods such as port and polish etc later to get that at this point this would be fine with me.
